Previous in Forum: LabVIEW   Next in Forum: SolidWorks PDM Vault Question
Omitting Access to VBA+Excel Sources
08/18/2009 3:17 AM
Hi
I use Excel +VBA to write codes and create softwares related to my calculations. Does anyone know how I can change the appearance of my softwares, so that no one would be able to access its source and equations? I want to give my softwares a neat look in the design mode so no one would tell this has been done in Excel.
Thanks
Re: Omitting Access to VBA+Excel Sources
08/19/2009 6:46 AM
The link below may be of some use to you. This web site is quite good for hints and tips for excel VBA
http://www.ozgrid.com/VBA/protect-vba-code.htm
08/24/2009 5:17 AM
Your best bet is to use MS access
Not sure if you have tried MS access
you already know vba
the formula's you use in excel
can be created on a MS access form
when you are done you can compile MS access
with passwords and user rights
and also write code to access the CPU serial number
HD serial Number
date etc to lock any one out from viewing your code
you can use form design to layout the data the with the look and feel
you desire
and you have send key capabilities to start another program
send it what ever and collect it
then remove it and apply your data inside an access table
while you have the MS access form open
Hope this helps
Johnny Flash
Register to Reply 2 comments
