Previous in Forum: Reactors in Power Factor Corrector   Next in Forum: Transformer Calculation
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Tan Delta Testing
08/18/2009 4:59 AM
how can we measure tan delta? why it is neccessary to measure?
Re: tan delta testing
08/18/2009 5:34 AM
Hi, Manir
Tan Delta could be measured with a TanDelta Test equipment along with Hi-voltage VLF 0.1HZ source and it should be less than 1.2X10-3 for healthy XLPE cables.
TD is an excellent diagnostic tool for MV XLPE cables.
TD is indication of aging of cable.
As the cable losses increase TD value will increase.
TD is used to optimise over voltage testing and limit the stress of cables.
Good luck
08/20/2009 1:47 AM
we are testing in power trafo of 100MVA 220kv/33kv. we apply 2kv and 10kv in trafo for tan delta. result come .004. so what is this .004. is it tan delta=.004 or angle delta=.24 degree
Register to Reply 3 comments
Anonymous Poster (1); manir_b4u2002 (1); manzoor14 (1)
