Previous in Forum: Compressors and Pressure Build-Up Capacity   Next in Forum: Pipe Wall Thickness
Material for Evaporator and Condenser Coil
08/20/2009 10:01 AM
Hey frnz,
I wanted to know what is the material used for evaporator and condenser coil in refrigerator.
And i also want to some of the selection criteria for material of evaporator and condenser coil
Mansi
Re: Material for evaporator and condenser coil.
08/20/2009 12:20 PM
In home refrigerator ,
condenser soft steel , the black on the back
evaporator aluminiun , 2 copper tails to allow solder to coppers pipes to compressor suction side , and the capillary .
Condenser Cost.
Evaporator heat transfer .
old fashion evaporator copper hot dip tined.
devitg
Re: Material for Evaporator and Condenser Coil
08/21/2009 1:37 AM
Generally for tubes copper is used and for fins aluminum is used. Materials for heat transfer equipment should have good heat transfer characteristics. You can refer any material science book .
08/21/2009 9:48 AM
......what is the material used for evaporator and condenser coil in refrigerator.
More information is required..........evaporator coils may be made of stainless steel, plain carbon steel, copper etc...............same goes for condensers, e.g. stainless, copper, 90/10 cupro-nickel, etc.
What refrigerant are you using (India-could be R12......we hope not)), plant capacity, environmental problems, are you chilling brine, etc., etc., etc.
I certainly hope that you are not considering manufacturing a refrigeration plant, or for that matter even trying to repair one!!!
Register to Reply 3 comments
devitg (1); MOBI (1); mrswamy (1)
