Previous in Forum: Steam Speed Record Seems Shaky   Next in Forum: hydrogen +oxygen gas run cars
Anti-theft light blinking
08/21/2009 7:08 PM
I have a 1997 Chevy Cavalier and the anrti-theft light bliks every now and then. When it does, I can't start the car. any suggestions?
Re: Anti-theft light blinking
08/21/2009 7:40 PM
  1. Try one of these:
  2. 1997 chevy cavalier w anti-theft device (red bli... - JustAnswer1997 chevy cavalier w anti-theft device (red blinking light in car) I dropped the push button thingy that turns the anti-theft device off (all broken) and ...
    www.justanswer.com/.../1ijti-1997-chevy-cavalier-w-anti-theft - Cached - Similar
  3. replaced battery in 1997 cavalier,anti theft lig... - JustAnswerChevy question: replaced battery in 1997 cavalier,anti theft light came on ... the theft system light is still on,was never blinking too start with,tried ...
    www.justanswer.com/.../z0s2-replaced-battery-1997-cavalier - Cached - Similar
  4. WikiAnswers - On a 1997 chevy cavalier how do you disable the ...Leave the key on with the theft system light flashing. ... Vats system on a 1997 chevy cavalier? Disable the antitheft 97 chevy cavalier? ...
    wiki.answers.com/.../On_a_1997_chevy_cavalier_how_do_you_disable_the_theft_system_from_activating - Cached - Similar
  5. WikiAnswers - If the antitheft light is blinking on a 2000 Chevy ...ALL GENERAL MOTORS PRODUCTS FROM 1997-2005 CONTAIN AN ANTI-THEFT SYSTEM ... 2000 cavalier theft light is blinking and car won't start what happened? ... Your antitheft light is blinking on your 2000 Chevy Malibu and your car won't start ...
    wiki.answers.com/.../If_the_antitheft_light_is_blinking_on_a_2000_Chevy_Malibu_and_the_car_will_not_start_how_do_you_fix_this_... - Cached - Similar
    Show more results from wiki.answers.com
  6. 1997 Cavalier won't start! =*( Passlock? New PCM... - FixYaDescribe your 1997 Chevrolet Cavalier Problem. Get Immediate Assistance! ... The anti-theft light would come on - not flashing, just staying on steady. ... My blinker started blinking really fast, is this a relay. ...
    www.fixya.com/.../t797730-1997_cavalier_start_passlock_new - Cached - Similar
  7. '97 Cavalier - will turn over for a second or two, then shut down ...14 posts - 12 authorsMy 1997 Chevy Cavalier Has A 2.2 OHV Engine, Approx. 150000 Miles. ... I think these cars have and anti theft device, but I don't know how to turn it off. ... I replaced the ignition on my '96 Chevy Cavalier and the theft light came on. ... turn the key forward (don't start the car) and let the theft light blink. ...
    www.topix.com/forum/...cavalier/TRU664OCV5BH5CLD6 - Cached - Similar
  8. 1996 Chevrolet Cavalier theft system trips for no reason ...Cavalier 2.2L. Automatic transmission; 158000 miles. My Anti-Theft only kicks ... it will catch - then die and the Anti-theft light on the dash is blinking. ...
    www.carcomplaints.com/.../Cavalier/.../theft_system_trips_for_no_reason.shtml - Cached - Similar
08/21/2009 11:50 PM
A shop that has a Tech2 GM scan tool, and a technician well versed in the security system can use the scanner to find out what is causing the problem. There will be codes set in the security module that will give a direction to the problem. Trying to fix something like this without the proper equipment, training & information can be quite costly.
Test first, replace parts later
Good Answers: 27
08/22/2009 11:49 PM
I presume you have keyless entry? If so, you might try locking and unlocking the door with the key. That should prevent the anti-theft alarm from setting.
You can also prevent it by shutting down the engine then turning the ignition switch back on briefly before turning it to off and removing the key.
Hobbies - Car Customizing - New Member
Good Answers: 11
08/23/2009 12:14 AM
Usually the ignition lock VATS module is failing.
A scan tool may pin it down.
The the part is relatively expensive, around $200.
To reprogram after installation:
Crank to start. It will stall (turns off the fuel pump) and the anti-theft light will flash.
LEAVE THE KEY ON!!!!!!!!!! the light will remain flashing, for up to 20 minutes.
When it stops flashing, turn the key to off, then start normally. Use a battery charger, if your battery is marginal.
08/23/2009 9:03 AM
Disable the system. Car is not worth taking care of anti-theft system. Feel happy if some one attempt to steal the car.
Masyood
08/24/2009 10:39 AM
While this is not a collection car, there might be good reasons for the owner to keep it, maybe he received it as a gift, or has a lot of memories or just for economic reasons.
I have a 1976 vehicle that is worth to keep its anti-theft system working, it's a JEEP CJ5 in pretty good condition and has given me lots of wild adventures.
Yahlasit
Anonymous Poster (1); Bluestone (1); bwrench (1); lyn (1); Masyood (1); Yosemit3 (1)
You might be interested in: Anti-seize Compounds, Anti-malware Software
