Previous in Forum: View vehicle data on your Mac or PC.   Next in Forum: Valve stockist In Singapore
Research on Valve Pipe & fittings
08/24/2009 11:00 PM
Hi i am George. Currently i am sourcing for some manufacture which are making good Valves & Fittings & Pipes in China and Korea. Alternatively Joint Venture can be consider. Can anyone out there advise me?
Valves
Ball, Gate, Globe, Swing Check, Wafer Check, Rubber-lined / High Performance Butterfly, Pressure seal Valve / Bellowseal Valve / Jacketed Valve / Plug Valve / Stop Check.
Valve size - 1/4" - 36"
Valve rating - Class 150 - 2500 / PN / DN
Material - Ductile Iron / Bronze / Carbon Steel / Alloy Steel / Stainless steel / Duplex
Tubes, Pipe & Fittings
Tubes & Pipes size - 1/4" - 48"
Fittings size - 1/4" - 48"
Rating - Class 150 - 600
Thanks!
Re: Research on Valve Pipe & fittings
08/24/2009 11:10 PM
Take your post here:
Commercial Space
06/01/2010 1:48 AM
Hi George how are you ? i am Patrick i hope to see you are still looking for a valve supplier let me Briefly introduce myself, i am valve supplier from China , currently i am base in Indonesia and we are supplying mostly to oil and gas company over here . i produce all sorts kind valve. basically almost all the valve you mentioned and off course all complied to API , DIN STD. so if you are interested please do not hesitate to contact me on Pakpetrick@hotmail.com thanks
You might be interested in: Hose Fittings, Valve Actuators, Tube Fittings
