Previous in Forum: inst earthing   Next in Forum: density measurement of natural gas
12 comments
Difference betn. Proximity sensor & Proximity Switch
08/28/2009 11:30 AM
Hi,
What is the difference between Proximity sensor & Proximity switch?
Thanks in advance
Regards
mech_rulez
mech_rulez
Pathfinder Tags: difference Proximity sensor switch
Re: Difference betn. Proximity sensor & Proximity Switch
08/28/2009 11:37 AM
proximity sensor produces an output signal. proximity switch opens or closes contacts.
08/28/2009 11:39 AM
Sounds good to me.
08/28/2009 11:57 PM
Thanks!
08/28/2009 11:42 AM
What kind of o/p signal? Do you mean NO, NC?
can you plz give me example of both?
Thanks.
mech_rulez
08/28/2009 11:52 AM
Would you please explain why you are confused? Do you not understand what a switch is?
08/28/2009 11:58 AM
Switches are mechanical type(contacting)....
s does this means Proximity switches also are contacting type...????
mech_rulez
08/28/2009 11:55 AM
No. Go find your own examples on Search GlobalSpec
08/29/2009 8:16 AM
thanks for the quick help....
mech_rulez
Good Answers: 101
08/28/2009 12:00 PM
switch   
1. a device for turning on or off or directing an electric current or for making or breaking a circuit.
sen⋅sor 
1.a mechanical device sensitive to light, temperature, radiation level, or the like, that transmits a signal to a measuring or control instrument.
Good Answers: 18
08/30/2009 2:38 AM
A prox sensor is a prox detector; it detects that a certain type of object (or whatever) is close (within range). A switch is a device that has contacts that open or close when a signal is sent to it. A prox switch is a switch activated by a signal sent by a prox sensor.
What you're describing is most probably a prox sensor that generates an electrical signal that activates a prox switch. These two can be separate from one another, or they can be both built into a single unit.
Cheers!
DZ
Do unto others. Then run.
08/30/2009 3:20 AM
"A prox switch is a switch activated by a signal sent by a prox sensor."
@DreadZontar"
Thanx, thats wat i wanted......
mech_rulez
10/14/2009 4:59 AM
exactly.. a proximity switch is operated by a proximity sensor..
proximity sensor is used as a tool for other proximity driven equipments..
If something you have is still working, you are not an Engineer..!!!
Register to Reply 12 comments
DreadZontar (1); lyn (3); mech_rulez (4); mechmerizer (1); redfred (2); RVZ717 (1)
