Greetings All,
I am designing an adapter that will allow me to use a Die Hard 19.2V Li-ion battery, normally used with cordless tools, with my own devices. The battery has contacts that are similar to 1/4" Quick-Connect male terminals. My application requires that the battery be un-modified (so it can be recharged in the stock Die Hard charger) and that it utilize a blind plug-in connection similar to that used on the stock tools (so I can't simply connect female Q-C terminals to the battery terminals).
A rendering of the battery is shown below. Note the plastic structures around the contacts that limit the size of the mating terminals. Also shown are a couple of possible mating contact designs.
I am trying to locate some standard, stock wiping contacts that I can use in the adapter. The two designs above are the general shapes that I am looking for. The first design is based on the contacts used on a hobby-type knife switch that is sold by Radio Shack (Model 275-1537). Originally, I had planned to just buy these switches and liberate the contacts. Unfortunately, the samples that I obtained most recently from my local "Shack" have changed the design of the contacts from a pair of inverted "U" shapes to to a pair of inverted "V" shapes. These only contact the mating male terminal along the lower edges of the "V" and do not give the wiping action I am looking for.
The second design is based on the contacts in the Craftsman tools that are used with the Die Hard batteries.
The overall sizes shown (.42"H x .2"W x .35"W) are rough maximums required in order to fit into the spaces delimited by the plastic structure around the battery contacts. The hole shown is clearance for a #4 screw that will come up from below and mate with a small pattern 4-40 nut that must fit inside the contact. The devices I am hoping to power from the battery will have motors and lights as well as control electronics and will require currents in the range of 1-2A continuous and perhaps 5A peak for 10s of seconds at a time. Because a newly charged battery will have to be installed for each use of the device, the contacts will need to handle hundreds to a few thousand insertion/withdrawal cycles (similar to any cordless tool that is frequently used).
I have been unable to locate stock contacts of either variety from my normal sources (Keystone, Google [search for wiper contact]), so I was hoping that someone here might know of a source.
Thanks for any assistance.
Les
