Previous in Forum: Welding   Next in Forum: hydraulic oil
8 comments
valve
08/29/2009 1:25 AM
hey what is the criteria for selection of direction control valves. is it flow restriction. i am supposed to use 3/2 valve(3 position, 2 way).
Good Answers: 183
Re: valve
08/29/2009 5:33 AM
Or 2 position 3 ways?
Re: valve
08/30/2009 2:01 AM
"2 position 3 ways", Very right.
Can a '3 position 2 ways', possible?
Common, '2 position 3 ways' are basically ball or plug types.
Typical applications include: valves at filters and coolers.
Typical requirement: to divert the common inlet flow to one or the other filter (or cooler). Advantage: Shutting down one filter (or cooler) and commissioning the other can be simultaneously done by a single quarter/half turn.
Normally the flow restriction is not preferred but might happen for cost/economical reasons.
Good Answers: 183
Re: valve
08/30/2009 7:34 AM
3 positions 2 ways is possible with both closed or open.
3 positions 3 ways as well.
Choice made for the expected flow and wished pressure drop.
Re: valve
08/31/2009 5:47 AM
Can you please include a 'graphical symbol' of this 3 position 2 ways valve...
Re: valve
08/30/2009 8:05 AM
Thank You for such a nice reply
Re: valve
08/30/2009 12:06 PM
With this valve you are not able controll things and you have to be in 2 positions with 3 way valve or 2 or something like that.i think you need to have a mogulation valves with multi step positions and controlle it with a driver if you wanna make a easy robat.
raybaxi
Re: valve
08/30/2009 1:49 AM
yes, basically it depends on your need too
Re: valve
08/30/2009 8:55 AM
This is called a non-proportional diverting valve. Honeywell is a great resource for selection- you have to know a little engineering, though.
Register to Reply 8 comments
Anonymous Poster (1); DRFREON (1); kuki (1); nick name (2); raybaxi (1); yesyen (2)
