Unless water lilies contain ethanol (I doubt this), ethanol can't be extracted from them.
That being said ... a high proportion of vegetable matter consists of polymerized sugars (cellulose, hemicellulose), which CAN be turned into ethanol. One way to do this is to grind up the vegetable matter and put it in a water-filled tank to which enzymes are added. The enzymes break down the cellulose/hemicellulose to make simple sugars. The sugars will dissolve into the water, and once the enzymes will have done their work, taking the water out will take the sugars out too.
After that, just add yeast to ferment the sugars and wait for them to turn to ethanol.
thank u so much sir. but there are ongoing studies that water lilies can be a source alternative fuel. so , what is that alternative fuel that we can produce out of those water lilies? thank u so much sir.
Good day sir. I have read your comment on cr4. Im just hoping if you can give me procedures upon doing n experiment in water lily. I just wanna know how to turn water lily into bio-fuel. I hope you can help me about this sir. Thank you.
I also wanted to know more about this research. Actually,i'm on my research now,and we have the same interest. I mean topic,about water lilies. Hope we can share knowledge to each other regarding this. Thank you and GODbless.
