hi
i am intrestet on the rotating machinery & its accesories.
- What are the main reasons of knocking sound from a reciprocating compressor.
- what are the taper pins & Why taper pins are used in rotating machines?
- If a diaphragm type dozing pump is not pumping, what will you check?
- How the interstage sealing is achieved in a compressor or turbine?
best regards
