Previous in Forum: Delay in EDG Starting   Next in Forum: ASTM Dimensions
14 comments
Torque Potential with Constant Force Springs?
09/01/2009 12:32 AM
What torque could a chained array of custom constant force springs absorb and is there a loss in winding and unwinding or mechanical gain?
Does it create a delayed gearing potential; such as by winding for thirty seconds at sixty rpm then allows 600rpm for 5 seconds with 6 spiral inner chords in an array of 10 constant force springs inside a torque retention cylinder? (I left out guages and material)
Re: What sort of torque potential with Constant Force Springs?
09/01/2009 12:48 AM
"What torque could a chained array of custom constant force springs absorb and is there a loss in winding and unwinding or mechanical gain?"
The laws of physics still apply. Give it up. This reeks of perpetual motion...........
Have a nice day. (Del made me say that)
09/01/2009 2:34 AM
Now I wouldn't say that, of course it was the first thing I thought, I just wouldn't say it.
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
09/01/2009 2:49 AM
I have an application in mind that uses my heavier torque input and runs it as higher rpm to match an overspeed addition to my electric bikes top speed. Is that ok with you? :)
Good Answers: 247
09/02/2009 1:52 PM
Regen braking in a hydraulic/diesel hybrid is effectively storage of energy in an air spring (typically the compressed nitrogen in an hydraulic accumulator). This air spring could be used for peak averaging as well, (thereby keeping the diesel operating close to its efficiency peak most of the time) except the amount of energy stored is too small to be useful. Mechanical springs would be the obvious, simple hybridizing method, but simply cannot store meaningful amounts of energy -- they are far worse even than hydraulics.
Start by doing the math.
Springs are great in their lack of hysteresis -- in other words, they return practically all the energy that goes into compressing them. Unfortunately, their energy storage vs weight ratio is rotten. Those windup keys you used to see on the back of early VW beetles were not real.
09/02/2009 2:30 PM
Unless you use a cunnyngle shaypeyd Yew stayve
Good Answers: 247
09/02/2009 8:11 PM
For some reason, the word cunnyngle reminds me of an old high school friend, Connie Schwartz, who married Jim Lingus.
Good Answers: 114
09/02/2009 9:34 PM
Good Answers: 68
09/03/2009 1:28 AM
Hello BJ,
This application sound good, now you have explained it a little more. Good luck with trying and keep in touch please?
Take care
09/01/2009 2:55 AM
<Splarf>
Damn tea on my monitor now
09/01/2009 12:02 PM
What amount of due diligence pays the wisdom for this? A rich man may never admit he became so; and similarly a bad person may never admit they chose to become one; all is accounted by deed. What choice reeks?
09/01/2009 2:54 AM
Interesting question, you could wind a spring at varying tensions, but they would only be held if there was sufficient friction to stop the tension evening itself out.
Of course the friction would be the enemy of efficiency.
There are mechanisms to give changed gearing or constant force. Google 'fusee'.
Years ago we made rubber powered dragsters, the rubber cord was wound around the back axle, to give a power boost as the rubber un-wound and became less taut we wound the first turns onto a bigger diameter section of axle, and the final (high tension) turns onto the narrowest diameter part. This avoided wheel spin at the start.
Good Answers: 68
Re: Torque Potential with Constant Force Springs?
09/02/2009 7:41 AM
Hello Brett,
Is there any chance you can shed some light on why you want to set this, seemingly difficult to impossible 'thing' up? Are you making a gun?
I would be obliged if you could reply please as we may............... Just may be able to sort something out.
Take care.
09/02/2009 11:21 PM
Here's help for you! http://search.globalspec.com/ProductFinder/FindProducts?query=constant%20force%20springs
or try; http://en.wikipedia.org/wiki/Constant-force_spring
Perhaps if I asked "what book takes an in depth view of constant force spring mechanics?"; but I didn't think this was a book club!
Thanks everyone for trying!
Good Answers: 68
09/03/2009 1:33 AM
Hello BJ,
CR4 may not be a 'book club' per se, but anything which gives details and info' for whatever use is open to all, and it may be a small Manual or book is of more use 'in the field'?
Take care my friend
Register to Reply 14 comments
babybear (3); Blink (2); Brett Johnston (3); Garthh (1); lyn (1); user-deleted-1105 (3); YWROADRUNNER (1)
