Previous in Forum: Energy Consumption of Heater and Pump   Next in Forum: what is the way of calculate coil width of round Pipe
Cutting Wheel
09/01/2009 11:26 PM
Efficacy of a Cutting wheel should be determined on the basis of effective surface area cut, keeping all other parameters unchanged. True or False
Re: Cutting Wheel
09/01/2009 11:31 PM
Ok, what "other parameters" are there?
Re: Cutting Wheel
09/02/2009 2:48 AM
Material, speed, feed rate, coolant/cutting fluid, cynicism of the operator.... can I stop now
My answer is 'true'
Good Answers: 103
Re: Cutting Wheel
09/02/2009 5:59 AM
I can not vote unless I know the parameters that are unchanged (obviously the homework question didn't mention those).
However when we buy the cutting wheels- rather the bits (and pieces ) of it, it is the other parameters that decide along with the base material whether I go for K20 or SNMG or other hundred types bits available.
And there it is not the life of the wheel that is the one of primary concern- it is the optimum utilisation of the machine tool (whose per hour rate is much more than the cost of the bits).
Only wheel that is cutting is the grinding wheel at our place.all others these are the bits and the wheel (we call it cutters) only holding the bits.
lyn (1); sb (1); user-deleted-1105 (1)
You might be interested in: Cutting Services
