Previous in Forum: Stepper Motor Power Rating?   Next in Forum: Increasing the Efficiency of an Old Boiler
10 comments
Conveyor Spillage at Metal Recovery Plant
09/04/2009 1:58 AM
I am presently working on a project where the size of 300*300mm is being handled by the conveyor. The conveyor spillage is a problem there.There are 2 bins which feed a common chute to conveyor belt. It has been observed that even when the conveyor is without any load, even then at the tail end the conveyor is swaying towards one side. Then at a distance of around 75m from tail end the same conveyor was swaying in a different side than that at tail end.
There are 2 feed grates which are filling the bins and then the feeder to conveyor belt. When under load, if one feeder is feeding and other is not due to no material in its bin, then the belt sways towards the feeder side which is feeding it.WHY?
The Conveying system is at an inclination from tail end to head end up. When the material is being conveyed, then this spillage increases due to gaps between the belt edge and the horizontal guide provided.
Even the sway control idler doesnot work.
IS there a problem of misalignment there?
What are the possible and practical engineering solutions which i can provide to solve it?
Please suggest.
leftSIDE FEEDER
right FEEDER
Pathfinder Tags: srikant123
Re: CONVEYOR Spillage in Metal recovery plant at TATA STEEL.
09/04/2009 7:00 AM
Per your post, the conveyor problems do vary with the actual load on it.
If all rolling elements are fine and supposed to be working, and no evident misalignment is present, have you checked/examined all the conveyor structure to see if it's not bending in certain places when the load is passing over it? Just a thought.
Humm... suspicious you are...
Good Answers: 266
09/04/2009 8:04 AM
If the belt is moving to one side or the other with a load on it then the conveyor is not level side to side. The belt will want to travel to the side of least resistance with or with out material on the belt. Friction between the bottom of the belt and its bed would mean that it will travel to the down hill side of the bed. In that it is where it is being fed and if the material is being dropped on the belt. Years of use may have cause the support to shift on one side. Check the level side to side at all supports also the straightness of the incline.
If the belt is bowed with no load on it one of three things or both. The lace is not been installed perpendicular to the length of the belt leaving one side longer then the other or the take up section is miss adjusted. One other thing usually with new belt if the length of the belt was not cut parallel with the weave can cause this.
As to the belt moving towards the feeder feeding it. Check the bed to see if it is cupped to each side. where the material is being fed on to the bed.
Good Answers: 38
09/04/2009 11:30 AM
Many times people try to adjust the tracking by adjusting the wrong pulleys. Check for proper alignment of the head end, tail end and bend pulleys. If it has a screw take-up make sure it's equal on both screws. Adjust your tracking using the load and return rollers. If tracking is not possible, your belt is either stretched on one side, or as stated above, not cut and laced properly. Possible damage to the framework may be attributing to the problem. Check that automatic tracking is free and working properly. It should be 90 degrees to the belt. If it is not it will never work correctly.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
09/09/2009 12:44 AM
Dear Light,
An elementary observation: if the belt had a flaw or more than one, the observer would see the repeat pattern, round and round, and discern the flaw to be inherent in the belt. If the flaw is localized to the observer, then the flaw would be physical to the location. However, we see the behavior meander with load. Neither fixed to the belt, nor fixed to a location. This leads us to, a maybe, the culprit might be the loading with its substantial variances.
Sounding out, hoping for light. We practice such insinuations here among the lesser bulbs at CDI.
L. Nordell
To Understand is to Engineer
Re: Conveyor Spillage at Metal Recovery Plant
09/06/2009 1:20 PM
The conveyor responds to the physics imposed on it. Your feed geometry needs to be modified to maintain a belt in its central position. It should not be too difficult to deduce from looking at the chute geometry the obvious present and future change.
The installation looks in need of proper maintenance and repair. Idlers need to be properly installed, skirts need to be installed with neutral influence. These are not evident.
Conveyor Dynamics, Inc. (CDI) practices the design of chutes on a daily basis.
Lawrence Nordell
President
www.conveyor-dynamics.com
nordell@conveyor-dynamics.com
09/06/2009 1:28 PM
A second comment:
The belt behavior you note of swaying without load, is due to inappropriate alignment of the idlers/structural support of the idlers. It is evident from your photo of the idlers, that they are in need of re-alignment. If the idlers are canted, or aligned off their theorectical ideal position, in 3 of the 6 degrees of orientation, then the belt and material on the belt will cause the central position of the belt to follow the new physics.
Engineering Fields - Civil Engineering - Member Engineering Fields - Construction Engineering - Member Engineering Fields - Mining Engineering - Member United States - Member - Member Popular Science - Weaponology - Member Hobbies - Target Shooting - Member Hobbies - Car Customizing - Member
09/08/2009 9:22 AM
It appears most of your equipment is fairly old. It may be beneficial to speak with a belt manufacturer. U-shaped idler pulleys tend to outperform the type you have shown. After years of working in coal mines adn having every "belt foreman" adjust the belts the way he wanted, I couldn't figure out why my belts would work good for a few days and then spill everywhere. Mandate that only one person makes adjustments, and then watch the effect for a few days. The earlier comments concerning idler pullys are where I would start. Are you sure the tailpiece was installed correctly?
You cannot escape the responsibility of tomorrow by evading it today - Abraham Lincoln
09/08/2009 10:47 PM
First of all..a lot of thanks for providing suggestions. Then yes, the tail piece was once installed and then no alignment checking was done there. Can you suggest a simple method to do alignment checking and necessary corrections for that?
09/08/2009 11:09 PM
Is there any possibility that the spilcing practice can have an effect on the kind of problem i have discussed here
11/18/2010 7:31 AM
I agree with you comment is true...
Register to Reply 10 comments
Anonymous Poster (2); bhrescobar (1); charsley99 (1); mypolo (3); Old Coal Man (1); ozzb (1); SRIKANT123 (1)
You might be interested in: Flat Belt Pulleys, Conveyor Controls and Monitors
