Previous in Forum: 1991 Nissan Maxima - Heater Doesn't Work   Next in Forum: Compression test for a newly reconditioned diesel engine?
Noise Reduction and Two-Stroke Engines
09/04/2009 6:12 AM
Heyy guys i had an idea on reduction of noise of an 2stroke engine installed on a auto rickshaw. can u help me out with some suggestions??
Re: Noise Reduction and Two-Stroke Engines
09/04/2009 7:36 PM
If you have an "idea on reduction of noise of an 2stroke engine", share it with us.
I've got a lot of concepts in my brain, but I wouldn't ask the people on here for help, unless I had some idea of acoustics and how to reduce noise, if I were you.
The first thing that comes to mind is:
1. A muffler
2. If already equipped with a muffler, a larger, or more efficient, one.
Good Answers: 97
09/05/2009 11:57 PM
Cap the end of the exhaust pipe, drill a 9/16" hole in center of cap, insert a tube with corresponding outside diameter about 6" into hole and then weld. Leaving about a 7/16" inside diameter hole at the end of exhaust pipe, reducing wranggg!!!! to puff-puffffff...
09/06/2009 1:41 AM
I assume that you are working with an air cooled engine? If so, many times more noise is radiated out of the engine, than comes from the exhaust. The exhaust noise is easy to fix with a muffler, the noise radiated from the engine is the hard one. Please give use a little more information to work with, since different engine makes need different things done to them to quiet them down.
Test first, replace parts later
09/08/2009 10:32 AM
The adequate muffler is important. But use the wright one, because 2-stroke engines do suffer from exhaust restraints. Excess backpressure in the exhaust will make efficiency drop dramatically.
As mentioned, also look for enclosure sound protection. Maybe you could relocate the engine, or install a shroud with ventilation to the exterior of the building to help reducing noise inside.
Humm... suspicious you are...
Good Answers: 123
09/09/2009 12:01 AM
If the rickshaw is small, you could collect the noise in a heat proof plastic bag. At the end of the day, you could just empty the noise in another noisy area.Hopefully,no one will notice.
Bob
bhrescobar (1); bob c (1); bwire (1); bwrench (1); lyn (1)
You might be interested in: Noise Standards, Auto Dialers
