Previous in Forum: how to calcualate the flow rate base on valve opening% for equalpercent valve   Next in Forum: Instrument Air Pressure Requirements
flow transmitter releated question?
09/06/2009 1:43 PM
Which kinds of factor keep in mind at a commissioning of any type flow transmitter?
Re: flow transmitter releated question?
09/07/2009 12:27 AM
Gee, I hate to be obvious but you might help yourself by being a little more specific in your question to us. What kind of flow are you measuring? Here's a list of possible flows measured by mankind:
  1. Electron flow in a wire
  2. Fluid flow in a pipe
  3. Water flow in a river
  4. Gas flow in a pipe
  5. Air flow over a wing
  6. Magnetic field flow in free space
  7. Cattle through a corral yard
  8. Passenger traffic across Manhattan island
  9. Impertinent questioners to this forum
  10. Solar wind
  11. Heat transfer across a solid media
  12. Blood through an artery, vein, heart, lung, or cancerous tumor
  13. Concepts spreading across civilization
  14. Glacial ice migration
  15. Lava flow
Now that I've briefly touched on some of the myriad of measured flows known to mankind, you might also ponder how to measure, record and respond. Please know at least these few things before asking anybody for help. And remember to tell them at least what you do know. For the best way to not seem foolish is to not act like a fool.
09/07/2009 8:51 AM
GA to you!
However, I am afraid that the thread operner does neither understand your questions nor the "hint" about people understanding binary figures
nudnik
09/07/2009 9:49 AM
Will your, "flow transmitter" by hard wired or wireless?
09/07/2009 6:12 PM
Hi
first of all u should know what is your communication system, filed bus , hart , smart, then the range of variable you would like to measure , after that you should make the orifice plate calculation
i think for commmuissioning you must know range and communication type , about the factor it is depending in the pipe dimension, material density
this link may be help you
http://www.wontu.fr/DOCS/transmetteur_de_pression_generalites-ENG.pdf
Register to Reply 4 comments
Ali Zude (1); lyn (1); nudnik (1); redfred (1)
You might be interested in: Gas Flow Meters, Radio Transmitter ICs, Flow Meters
