Previous in Forum: SAP PM   Next in Forum: ASME Section v111
How to Design Cooling Coil in Air Handling Unit (AHU)
09/10/2009 3:29 AM
I have the following data
Air quantity 3157cfm
Desired room temp 22 degree
Outside temp 38 degree
Desired RH 55%
Chilled water type chiller
supply water temp 7Degree Return water temp 12 degrees
Chiller capacity 40Kw
Re: How to design cooling coil in AHU
09/10/2009 8:53 AM
Is this homework? Looks like homework. We don't do homework here.
Also, it seems you have mixed imperial and metric units.
In any case, it appears that you need your instructor's help.
