Previous in Forum: ASME Section v111   Next in Forum: Ebullating Assembly?
Fan Shafts
09/10/2009 5:49 AM
hollow shaftwith of high speed centrifugal radial fan can be better than solid shaft with fan?
Re: about hollow shaft
09/10/2009 5:54 AM
It depends on your application characteristics.
A hollow shaft has less mass compared with a solid shaft with the same stiffness. This is the main difference. But, if you have vibration dampening issues or special failure mode needs, maybe the solid one should be used.
Or, your fan should be done so quick and inexpensive that you just do not botter about being solid. Or not.
Humm... suspicious you are...
Re: Fan Shafts
09/11/2009 12:00 AM
It doesn't matter. Solid shaft will produce more run-out than hollow.
Try some more details.
You might be interested in: Core Shafts and Mandrels, Rotary Shafts, Linear Shafts
