I have patented the first practical system that allows the utilizing of deep-ocean hydrothermal vents for energy production. Please see my website at www.marshallsystem.com for an animation and general description.
In a nutshell, the system caps the vent with an insulated pipe that goes from ocean floor to surface, and it is ducted through that pipe to an oil platform stationed above the vent that holds the generators.
I have an absolutely huge volume of superheated water to deal with. The flow from a 1 meter diameter pipe at a velocity of 3m/sec is 2356 l/sec, or almost 8.5 million l/hour. When you increase that pipe to a 2 m, it becomes 34 million liters/hour, and at 3 meter diameter, which is feasible, the number is a staggering 76 million liters/hour.
That tremendous volume is delivered at temperatures of 350-400oC. The raw energy content is in the tens to dozens of gigawatts range, but I need an effective method of extracting that heat energy and putting it to work spinning a turbine.
I'm starting this thread to ask the learned folks here for their input on what method of heat exchange they think might be best given the needs. It should be noted that the hydrothermal fluid is both acidic (2.8-2.5 ph) and laden with particulates, as well as being very fast moving. Hopefully someone will have a suggestion.
I've also considered something that might work that I'd like to bounce off of all of you for comment.
Once the hydrothermal fluid is on the platform, I've envisioned the flow being directed downward, and at the bottom of that downward flow a cold gas is injected directly into the stream. It would rise through the fluid and be heated. It would expand, of course, while removing heat from the stream, and I'd like to use that now superheated and expanded gas to drive a turbine.
In other words, no mechanical heat exchanger at all, just the gas passing through the moving fluid.
Is such a thing possible? Which gas would be best? How could it be recovered after it is heated?
I'd love to hear any thoughts posted.
