Previous in Forum: Induction Charger Basics   Next in Forum: Space Heater Calculation
Mean Double Front and Back-to-Back
09/14/2009 5:38 PM
Hi, someone can explain about the terms back to back and double front on LV MCC, if mean the same thing or are different terms.
Thanks
Re: mean double front and back to back terms
09/14/2009 11:58 PM
Maybe, back to back means that two cabinets are placed, get ready, back to back.
Double front could be side by side.
Depends how many times the manual has been mutilated by nonsensical translation.
09/15/2009 11:13 AM
well, basically the question is about the typical LV motor control centers arrangements, Which are the back to back configurations, if you check the Square D, technical documents, it show two differents arrangements (back to back with transition section, and back to back through the back splice, each one with the 20" of deep) this with the objetc to reduce the space on the electrical rooms, specially on marine applications, obviusly with this arrangements we have the double front, and the main concern if exist other configuration for this term?
Re: Mean Double Front and Back-to-Back
09/16/2009 5:01 AM
When installing MCC's please take note that to carry out electrical maintenance on the bus bars you need to get get acees to them.. then they have been insatalled on site here they have been put against the walls and you can not get access to check the thighness of the busbars connections. All we can do here is take the end panels off and do a visual from the ends. Please check what maintenance is required before you decide on the way the island is constructed and how you are going to intall them in the switchroom for maintenance in the future. hope this helps
Raise to the challange and do it safely
09/24/2009 11:38 AM
the basic idea about the mcc double front is to use optimal space on the electrical room, but is necessary to know the standard to support the use on marine facilities
Register to Reply 4 comments
Anonymous Poster (1); jeffweeden (1); lyn (1); nickjr (1)
