Previous in Forum: AC Servo Motor System Trip   Next in Forum: PLCC Requirement for Transmission Line
How to Test Single-Phase Isolation Transformer
09/15/2009 5:54 AM
dear sir .
could you guide me how to test the isolation transformer / single phase .
and so is i use a lamp for testing between the primarey and secondery winding does it lighting if i use a primery phase with a secondery neutral .
regard
Re: how to test single phase isolation transformer
09/15/2009 6:51 AM
Not quite sure what you want to test - do you just want to know whether it's working (as a transformer), or do you want to test the isolation?
09/15/2009 7:31 AM
dear sir ;
thank you for rapid respond .
i want to know if its working as an isolation transformer .
regard
09/15/2009 7:54 AM
You can get an idea by using a PAT (Portable Appliance Test) tester to check for leakage between the primary and secondary, but this will only use (typically) 500Vdc. You will need an insulation tester (e.g. a "Megger") or high voltage generator to produce the 1.5kV, 5kV (or whatever the specification says) to do a proper proof test.
09/16/2009 4:48 AM
dear sir ;
thank you ;
i have a single phase isolation transformer 220v /15 kva , but when i mesure the voltage between the earth and neutral its 25 v .
so whate is the values that show me the transformer is good or not .
regard
09/16/2009 6:36 AM
You need to check leakage current from primary to ground, primary to secondary and secondary to ground all with the transformer disconnected from supply and load, and with a DC (NOT AC) test voltage.
The 25V earth to neutral that you're measuring (which is AC) tells you little, if anything, about the isolation.
