Previous in Forum: Nitrogen and Ambient Air   Next in Forum: Improving welding environment
PP dissolution
09/18/2009 9:34 PM
Please suggest the best solvent for dissolving polypropylene.
V.Murali krishna
Re: PP dissolution
09/19/2009 12:36 AM
There is no solvent that will "dissolve polypropylene". Nor polyethylene. It's like trying to dissolve wax. They melt with heat, not dissolve in solvents.
Look up polyolefin.
Never mind.
Polyolefin - Wikipedia, the free
Re: PP dissolution
09/19/2009 7:45 AM
There is no conventional solvent that can dissolve polypropene! But you can try hot nonpolar solvent such as the hot xylene. You need heat it to 130DEG C.
China Plastics News
Re: PP dissolution
09/20/2009 10:14 AM
Veellu kaadu. Polypropylene is a polyolefin. It does not dissolve in any solvent. If you have some specific problem, please post details or send a message for suggestions.
bioramani
Re: PP dissolution
09/20/2009 11:14 AM
Looks like repeated redundancy, all over again.
Re: PP dissolution
09/20/2009 11:49 AM
Agree completely. Only, if the actual problem has some other solution than PP dissolution, one could look at it. We Indians tend to be repetitive too.
bioramani
Re: PP dissolution
09/20/2009 11:59 AM
Typical mistake. Yes, why does the PP need to be dissolved? Do you need removal? Repair? disassembly?
"Cut the affected area out and weld in a plug" might be an acceptable answer, if the question was posed more clearly. Maybe not, who knows.
It's always nice to know why the question has been posted.
Register to Reply 6 comments
bioramani (2); lyn (3); plaslog (1)
