Previous in Forum: Manifod Design for LN2   Next in Forum: parameter of turbine
Dessicants and Dew Points
09/23/2009 1:04 AM
Which Dessicant Can I Use to Get Dewpoint Around -70deg c
Iam working in a semiconductor industry,we use thermal forcing system to do characterisation for IC'S at different temperature ranging ffrom -50 degc to 150 deg cWe have 2 thermal forcing system,one of which is down because it is causing ESD(Electro static charges more than 10kv which iss bad for IC Testing.
Root cause we finally identified as AIR DRYER,which is not working fine.The Air Dryer is using Moecular seive as a dessicant with 60 seconds regenarion time .
As a measure of cost cutting we planned to souurce it locally(India).
Can ayone help me which molecular seive will help me to obtain -70deg c dewpoint.
Re: Dessicants and Dew Points
09/24/2009 12:06 AM
Suggest going for refrigerant drier. For details pl contact purna.design@gmail.com
Good Answers: 58
09/24/2009 8:31 AM
You report two independent problems. The first problem is electrostatic charging of your ICS by the use of dry air for temperature control. The second problem is how to dry the air most efficiently. The best molecular seive dessicant can be suggested by the manufacturer of the seive material. The charging problem is more difficult. I suspect you need an air ionizer to dissipate the static charge before it reaches the semiconductors. You also need to be sure that the conductive trays that hold the parts are properly grounded. I have seen testing systems where the semiconductors were charged to high voltage by industrial processes. The high voltage charge does not necessarily damage the device because the voltage gradients are small. The damage occurs when the tray of charged parts is subsequently placed on a grounded surface. Then-poof!!!
09/24/2009 9:02 AM
I agree. you have two problems. I cannot answer the static problem, but can answer the drying concern.
First, a refrigerated dryer will not get you down to the pressure dewpoint you are seeking. The dessicant dryer is the thing to use. A 4A Molecular sieve, alkali alumino-silicate, will get you down to about a -84.4 deg c pressure dewpoint. To get there you will need to use this dessicant and adjust the cycle time of the two towers for the dewpoint you want. This is done in the control box/panel of your dryer. You will need to read the manual for your particular dryer to see how to make the adjustment. Each manufacturer has their own proceedure.
Anonymous Poster (1); b v rao (1); welderman (1)
