Previous in Forum: Knee Point Voltage and Current Transformers   Next in Forum: DC Motors as Generators?
12 comments
Generator Life Expectancy
09/23/2009 10:38 AM
Can you tell me if there is a rule of thumb for the expected life cycle of a power generator? I realize there are many different types used for many different purposes but provided all maintenance is performed both scheduled periodic and unscheduled at the correct time intervals is there some standard that is used to determine life expectancy of generators?
United States - Member - New Member Fans of Old Computers - PDP 11 - New Member Hobbies - HAM Radio - New Member
Re: Generator life cycle expectancy
09/23/2009 11:42 AM
Are you talking about the self-contained units that are a combination of internal combustion engine and electric machine, or are you talking strictly about the electric machine that comprises the generator? It makes a huge difference.
09/23/2009 2:02 PM
Steve,
Hi! Hey, thanks much for the quick reply. Actually, I dont know for certain how to respond to your questions so if I can get information on both categories it would be super! Thanks in advance for any assist you provide.
Terry
09/24/2009 1:40 AM
Large generators (alternators) in power stations - upwards of 30 years.
Diesel driven genrators on ships - 20 plus years. Cheap and nasty household generators - a month after the guarantee runs out.
09/24/2009 9:05 AM
I can agree with that one. Had it happen myself.
Good Answers: 68
09/24/2009 2:01 PM
Hi Guest,
with regard to the "nasty home Generators", you are so right!
GA to you Sir.
Take care
Good Answers: 68
Re: Generator Life Expectancy
09/24/2009 2:11 PM
Hi tday,
I would have thought it depended on whether the Generator was your only source of power and how much you use it, and whether it was for a Factory or Domestic?
'Professional Generators' tend to work at low revs and are pretty big, so generating the power necessary is but a 'sneeze' to them, compared to say a car Engine which works at much higher revs and is very much smaller, so lasts comparatively little time.
Do not forget, starting up takes more by way of wear than having a generator 'ticking over' all day and perhaps with only one or two on/off cycles?
Take care.
09/24/2009 3:13 PM
All,
Thanks so much for the information. I was curious if there was some defining standard that I could extract from a reference source beyond professional opinion which you all so graciously provided? Again, many thanks!!!
Terry
Hobbies - CNC - New Member Hobbies - Musician - New Member
09/30/2009 6:37 AM
A day longer than when the warranty expires.
Think and move like an electron
10/03/2009 10:40 AM
Commercial steam turbine generators are designed for a 40 year life. Here in New England, there are plants still running post WWII units as standby, though they aren't efficient enough for base line power.
Hydro units seem to run forever. There are WWI vintage units still making kilowatts.
It's all about maintenance and the efficiency of the system.
How can you be two places at once when you're actually nowhere at all?
10/04/2009 5:57 AM
Jerry,
Thanks for your reply. I understand that maintenance is a HUGE part of keeping the system operational. Did not know that there were units still operating that were of WWI and WWII vintage. As far as maintenance and life expectancy is concerned does that vary by manufacturer? Or is there some standard that calls forth the required maintenance intervals and can you tell me more about the brands and types that appear to last "forever"? Appreciate in advance any additonal insight you could provide.
Terry
10/05/2009 6:17 AM
As far as steam turbine generators, the older General Electrics seem to have held up better than the older Westinghouse units. As base line units, the tear down / inspect / overhaul cycle seems to be once every four years, though after they went to stand-by status, the frequency was increased due to the number of start-ups and shut-downs increasing.
In hydro units there didn't seem to be all that much difference. The primary wear items are the wickets which are replaced routinely, and potentially bearings if lube is lost / interrupted. If you are dealing with water that carries a lot of silt, you may have to build-up the turbine itself, but I've only seen this done twice and both of those were very old. The pentstock and tailrace walls are monitored and built-up as required, but this has also been infrequent in my experience.
Hobbies - Musician - Tube Amps Only Please!
10/26/2009 11:19 PM
Well you described yourself that there are many variables and it is difficult to answer your question without saying what type of generator. Can you be more specific?
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
Register to Reply 12 comments
Anonymous Poster (2); babybear (2); DonC (1); Jerry New Hampshire (2); madness (1); maveric_manic (1); Steve (1); tday597706 (2)
