Previous in Forum: Torque Measurements   Next in Forum: Odd Order Harmonics
Wika Absolute Vacuum Gage Replacement
09/25/2009 2:16 AM
I would like to know if there is a digital replacement to the Wika analog gage, that is just as accurate? I need to bench calibrate Honeywell Smart transmitters down to .5 mmHg. Also, what is the best way make the connections so there is no vacuum leaks?
Thanks
"It is what it it is."
Pathfinder Tags: Vacuum gage
India - Member - ADIL MOULA Engineering Fields - Instrumentation Engineering - Adil Moula
Re: Wika Absolute Vacuum Gage Replacement
09/25/2009 11:37 AM
check this one druck DPI-605 approved for ISO 9000
http://www.rshydro.co.uk/Druck-DPI-605-Pressure-Calibrator-pr-16144.html
avoid minimum joints use teflon sealant to seal the fittings so you can reduced the leak to minimum if further needed u may require a motorised vaccum pump with vent valve so that you can set the value to desire setting for long time. so the reading gets stable before ajustment.
09/25/2009 2:36 PM
Mensor, Ruska, DHI, and many other manufacturers make very good units.
Register to Reply 2 comments
