Previous in Forum: Why not Second angle and fourth angle projecions?   Next in Forum: Pressure Problems with ASME VIII-1
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Establishing Visual Control
09/29/2009 5:01 AM
Dear All
In order to facilitate for operators to make it easier to report potential problem, visual controls need to be clearly identified and marked. This one will ensure thal all operators could detect if equipment is operating normal and having good operation. Simple visual controls are as:
- do a sign on a gauge for normal operating value;
- rotational arrows;
- painted nuts and location nuts to see if any loosening is occuring;
And we like to extend these kind of visual control. Any contribution, any suggestion, any recommendation to improve this kind of control will have a great value.
Thank you in advance for any advice
Look over to the next challenge
Re: Establishing Visual Control
09/29/2009 2:32 PM
You might also consider electronic gauges that monitor process variables like pressure, temperature, angle, etc. These can be used for a visual indication next to the equipment or even wired back to a central control room for remote monitoring. Additionally a large number of different variables can be monitored at once in one place (like on a computer screen or indication panel) without the need for the operators constantly moving around the equipment checking mechanical gauges located in different places on the equipment or plant.
You also may want to implement safety interlocks (either mechanical and/or electrical) which will give operators an indication if the equipment is safe to operate/clean/perform next step in manufacturing process, etc.
Here is just one example company providing customisable safety interlock systems
http://www.sick.com/group/EN/home/Pages/Homepage1.aspx
Also try Globalspec
http://www.globalspec.com/
Good Answers: 21
09/30/2009 8:54 AM
Dear CR4 member
Thank you so much for this valuable reply. Our intention is to install some visual signs on the equipmemt, trying to help the staff to observe from distance if the equipment is running well ( e.g. mean right rotation, a sign for proper level on the vessel level indicator, match marking on the bolts and nuts, sign of good oil level on the frame etc. ). The operators have some walkdowns, routes to check plant integrity. And there are another idea will be welcome to our programm.
Thank you and kind regards
Register to Reply 2 comments
You might be interested in: Nuts, Eye Nuts, Door Operators
