Previous in Forum: Cryogenic Piping Materials   Next in Forum: Valve Inspection Technologies
Pad Strength for Single Sided PCB
09/29/2009 12:07 PM
hi all,
i am karthick . can anybody tell the specification of single sided pcb pad strength. please consider this as urgent.
Regards,
Karthick.S
Re: pad strength- single sided pcb
09/29/2009 12:57 PM
Don't know where you are. Here in USA it used to be Mil-p-55110 or an IPC spec.
Go Fish.
Re: Pad Strength for Single Sided PCB
09/29/2009 10:38 PM
Please let me know the name of material and how much ounce of Copper is there.
Thanks
Naveen
Hobbies - CNC - New Member Hobbies - Musician - New Member
09/30/2009 5:37 AM
Things to consider: substrate type eg FR-4, thickness, copper thickness, 35/70 uM solder mask, pad size, round, rectangular, holed, before soldering or after, tensile or shear stress???
Suggest "google" for some answers, come back with specifics.
Think and move like an electron
09/30/2009 9:10 AM
hi..
below are the specification.
1. FR-4.
2. Copper thickness -- 35microns.
3. Rectangular pcb.
4. Tensile stress.
10/01/2009 11:48 AM
Adhesion strength of Copper plating on epoxy
resin is normally enhanced with barrier metals; such as
with Chromium in thin film polyimide systems, was
anticipated for this built-up process. To enhance the
adhesion of the resin surface, the surface is initially
treated with Potassium Permanganate to create "micro
anchors".
Of these micro anchors. The Ra of the epoxy surface
measured 0.06~0.1 mm for epoxy material and
0.18~0.21 mm for epoxy-acrylate material. Finer micro
anchors are formed on the epoxy surface than the epoxyacrylate
surface.Adhesion strength on micropads for flip
chip attached devices will affect joint reliability between
the device and package. Epoxy-acrylate is chemically
resistant to Potassium Permanganate treatment so the
surface is difficult to form these micro anchors. This
condition results in a weak micropad adhesion strength.
Micro anchors in the epoxy resin surface forms readily and
the adhesion strength meets the specifications. The
adhesion strength of the conductor metalization is directly
related to the material type and susceptibility to Potassium
Permanganate treatment.
Two to three mm micro anchors has a adhesion strength of
2kg/mm2. This value for the adhesion strength will meet
industry specifications based upon the experience gained
on the multilayer thin film Copper/Polyimide technology.
It is also equivalent to 1kg/cm of peel strength for standard
PCB technology.
09/30/2009 8:20 AM
Just an FYI: If you take Dramamine you won't be karthick -
09/30/2009 8:38 PM
use biggest pad as poss(chip size). and watch the heat (repairs)
Register to Reply 7 comments
Anonymous Poster (3); karthick285 (1); lyn (1); madness (2)
