Previous in Forum: Shoulder Screws - Pros/Cons   Next in Forum: Hot runner in epoxy
New Zealand - Member - Member Papua New Guinea - Member - Lapun
Steam Plant Deaerator - Inspection Check Sheet
10/01/2009 8:56 PM
I am in the process of reviewing plant inspection methods, and need to make up a new inspection check sheet for the visual inspection of large power plant dearators.
Would any member have a template available that I could modify to suit my needs.
regards
from the beautiful central North Island of New Zealand.
Re: Steam Plant Deaerator - Inspection Check Sheet
10/01/2009 9:24 PM
Check for cracking!!!
(and if you don't understand the significance of that statement - you probably should not be involved in developing inspection methods)
Good Answers: 68
10/03/2009 12:14 PM
Hi Coinneach,
I have not looked at it and obviously do not know in detail what detail is necessary, but, take a look at the top item or some others.......... Look at Project Template?
Oh, and ignore the Guest remark! Not at all helpful.
good luck bb
http://www.google.co.uk/search?q=visual+inspection+of+large+power+plant+template&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-GB:official&client=firefox-a
  1. Project TemplateProjectplace.com Standardise your project work using our customisable template features.
Search Results
      Results include your SearchWiki notes for
visual inspection of large power plant template
      . Share these notes
      Copy and paste this link into an
email
      or
IM
See a preview of the shared page
  1. Keith Price Bibliography Inspection Systems and TechniquesMethod for detecting optical errors in large surface panels, US_Patent6509967, Jan 21, 2003 ... Template-guided inspection of arbitrarily oriented targets, .... Kita, N., Visual Attention Control for Nuclear Power Plant Inspection, ...
    www.visionbib.com/bibliography/applicat835.html - Cached - Similar -
  2. Pipe Supports Visual Examination Procedure example needed4 posts - 3 authors - Last post: 26 JanPipe Supports Visual Examination Procedure example needed Documentation Systems, Procedures, Forms and Templates. ... I am Component Engineer responsible for the Pipe Supports Inservice Inspection Program in a large facility and I am ... Inspection Program for Pipe Supports in a nuclear power plant. ...
    elsmar.com/Forums/showthread.php?t=29189 - Cached - Similar -
  3. MULTI-AGENT BASED FRAMEWORK FOR LARGE SCALE VISUAL PROGRAM REUSEThe visual Function Block Language is used for power plant and paper machine controls. ... template matching. Again another agent is called for more detailed template .... Each search match can be taken to more detailed inspection. ...
    www.springerlink.com/index/y1501154w44630v9.pdf - Similar -
    by M Karaila - Cited by 4 - Related articles
  4. Inspection machines: NDT, Visual inspection, ... - Caliber79 products in Inspection machines: NDT, Visual inspection, . ... Power supply taken from the ROV • Only one twisted pair is required to transfer the .... Large memory capacity for storing up to 100000 readings in 10 and/or 100 batches ..... to recording various geometries such as tanks, cylinders, pipes and plant. ...
    www.directindustry.com/.../inspection...visual-inspection.../caliber-76013.html - Cached - Similar -
  5. [PDF] 2005 EPRI PowerPoint TemplateFile Format: PDF/Adobe Acrobat - View as HTML
    Engineering Database for. Large Steam Turbines. 6/7. Blade/Disk Design Audit and. Inspection Procedures ... Are there power plants near me that might have spare parts for my ... Visual Inspection Results. HP, IP, LP inlets and exhausts ...
    mydocs.epri.com/docs/Nuclear/STG_Guidelines.pdf - Similar -
  6. [PDF] IoA TemplateFile Format: PDF/Adobe Acrobat - View as HTML
    even small boats with large outboard motors can produce sound pressure .... based on visual inspection of the waveform and cross-correlation ..... Response of alewives to high-frequency sound at a power plant intake on Lake Ontario. N. ...
    www.awionline.org/ht/a/GetDocumentAction/i/10182 - Similar -
    by AR Scholik - 2001 - Cited by 7 - Related articles
10/04/2009 1:34 PM
Many thanks for the help. I will visit and look at each one.
We carry out an external visual inspection every 1/4, and annually there is a detailed internal inspection and certification by an independent 3rd party.
We are a new operation that has taken over an existing maintenance contract from another company, and we are running very fast to get improved systems in place. We don't want to be 100% concerned with the detail at present - just get the base work done - then come around again and polish up the system.
The engineering staff are very experienced in steam and power plant operation - but in the transition from one service provider to another, a lot of maintenance data was "lost".
Many thanks - from a very wintery and snow bound central North Island of New Zealand.
Good Answers: 68
10/04/2009 2:44 PM
Hi Coinneach,
Thanks for your reply post.
You could always list the items and factors to be checked and draw your own? Either by hand or computer, and or, print.photocopy them?
Have you checked the Format sheets on word or excel?
Take care.
Register to Reply 4 comments
Anonymous Poster (1); babybear (2); Coinneach (1)
