Previous in Forum: Servo Motor   Next in Forum: I need to build or buy a pure sine wave inverter that does 120VDC to 120VAC
Good Answers: 19
Inverter Duty vs. Premium Efficiency
10/02/2009 12:05 PM
A quick question for you Sparky's.
Inverter Duty motors seem to have better bearings, grounding and longevity when installed in a speed drive application.
Premium Efficiency motors offer better amperage ranges at full speed with no drive and run hotter (temp) with a drive.
Which is better when installed in a speed drive application?
HP is irrelevant to the q as well as voltage.
Thanks for your time.
Good Answers: 804
Re: Inverter Duty vs. Premium Efficiency
10/02/2009 2:40 PM
If you are using a VFD, use the inverter duty motor. Premium Efficiency motors mean nothing if the motor is not running full speed. If running full speed for any length of time (to where a percent or two difference in efficiency would make a difference), you should re-evaluate your need for a VFD. ANY motor application driven by a VFD will have decreased overall efficiency because the VFD has losses, so the only time you want to use a VFD is when speed control is absolutely beneficial and/or the use of the VFD decreases overal power consumption to begin with.
Good Answers: 19
10/02/2009 4:12 PM
Thank you for the vindication.
The VFD's are required not only for energy savings but to maintain the facilities static pressure. I speced the job with the inverter rated motors due to energy loss and bearing loss due to electrical drainage from the stator to the motor ground through the motor bearings, which I have seen many times in the past.
The customer (who is always right) pushed back and said premium. The ROI's have changed due to the Drive amperage needed to keep the motor at proper speed. the premium seems to suck more from the capacitance buss than the inverter duty motors.
Good Answers: 15
10/02/2009 11:16 PM
There are a lot of 18-pulse VFDs that can run a non-inverter duty motor without consequence. Even for those that are not configured to work with a Premium Efficiency motor, you can add a filter so that the motor is getting a clean sine wave. It will still run warmer at lower speeds, but it won't have the spikes that demand an inverter-duty motor.
Register to Reply 3 comments
JRaef (1); Mitsurati (1); Stedou73ish (1)
