Previous in Forum: where can find PDMS course training in saudi arabia?   Next in Forum: Calculation of Volume for 1 hr of pumping process
Use of Titanium or Titanium Nitride Coating (TiN) in Selective Soldering process
10/02/2009 1:34 PM
I want to improve the "cups" in a selective soldering machine, which is pretty much like this one: http://www.inertec.de/en/?Mass_Soldering_System. The idea is to reduce costs in maintenance and spare parts purchasing.
I think I can use "cups" made of Titanium, or I can use Titanium Nitride Coating instead. Currently the spare parts are made of AISI A2 and have a Tin plating finish.
Did you ever tried any of these ideas? What were the results? Are they worth the effort?
Thanks for your attention in advance.
Good Answers: 120
Re: Use of Titanium or Titanium Nitride Coating (TiN) in Selective Soldering process
10/02/2009 11:23 PM
does the company intentionally make their cups of an inferior material, so they can sell frequent replacement parts? Do the cups get damaged by being dissolved or by striking the components as they are stamped?
If you can make a single test part and use the material and see how long it endures.
This only works if mechanical damage is prevented
From the look of it, careful use means that the cup should never hit a part, just immerse the joint and parts in the solder = long life.
Sharp edges of cut components will soon damage the cups = short life.
Per Ardua Ad Astra
10/15/2009 10:58 AM
Actually it disolves, even though we brush them every two hours (manually) by the end of five weeks we have to replace them. We've already ensure that there's no friction between the cups and other components during the process.
So I think that the material or the plating does not resist corrosion well enough to last longer.
I've already made a research and people from other facilities tell me that making cups of Titanium is not such a good idea because it is not a good heat conductive material and that causes problems in the soldering process.
However, I still don't know if TiN coating will develop better results. Suppliers say that it could work because the coating is so dense that no material adheres to it, but I guess I have to test it as you suggest.
Thanks
