Dear all:
We have am Emergency Power-supply composed by 6 Gensets Cat 3508 B (so, 6 x 1000kVA)
The radiators don't have the same usage hours, but are between 5000 and 16000 running hours. At least 4 of the 6 were allways filled up with the CAT Coolant (100% pure, no mix).
The cores are leaking, who can help, to find the reasons?
There is no overheatings according Cat ECM module data.
The ambient temp can vary between 24ºC and 38ºC.
Normally the engines run between 25% and 65% of nominal load.
Thanks in advance
Domingos Velho
