Previous in Forum: Surface Finish...   Next in Forum: pipe sizes and pump size
Support Reinforcement Pad leak test
10/04/2009 10:31 AM
Dear all,
This is regarding Piping Reinforcing pads leak test.
Whether all the RF pad's need to be tested?like Branch connection, Support connection ?
As per ASME B31.3, its not mandatory.For critical areas like branch connection we do leak test.
But is it required to do support connection RF pads also? Is it a common practice?Any Client spec is asking for support connection RF pads leak test?
Please give suggestions.
Thanks and regards
Re: Support Reinforcement Pad leak test
10/05/2009 12:49 AM
Hi 887,
It is fairly common to leak test support RF pads because any heat input into metal through welding can cause hairline cracks. Whether or not you do leak testing every time depends on risk factors such as what product is conveyed, does it pose any flammability, health or environmental hazard, what are the financial or operational consequences of a leak, etc. Usually the piping specification will specify the need for the test, but a risk assesment exercise with a full design team will provide the correct answer.
10/05/2009 2:39 AM
You are right. B31 3 only ask for a vent hole for the reinforcements. Review your Project specifications, and read ASME VIII Ug 37 (g), possible can help you. regards
10/05/2009 6:13 AM
As a common good practice, for reinforcing pads for any pressure part like reinforcing pads for nozzles used in pressure vessel and piping connections, the designer shall furnish the pad with a threaded vent hole(s) 1/4" dia., and the fabricator shall proceed a pneumatic leak test by 1 bar or 15 psi.
For pads of support connections (looks like saddle plate in between the pipe and its support, or saddle plate in between the shell vessel and its saddle support), the designer have to furnish the pad with vent hole(s), but I think no need to proceed a pneumatic leak test, because the fillet weld around the support plate can be selected to be intermittent not continuous for certain cases.
09/07/2010 7:01 AM
Don't forget that if a repad is in more than one piece, each piece must be tested externally AND internally at the nozzle with air/soap. Good idea to plug the NPT hole with grease or caulking. However, grease may be a problem when you come tonpsinting the area. Doc
Register to Reply 4 comments
Abdel Halim Galala (1); Anonymous Poster (2); Garyvan (1)
