Previous in Forum: Is it possible to send or receive a fax via e-mail?   Next in Forum: Does Anyone Have Experience Using AskEd ?
mixing air with water/oil
10/05/2009 4:36 AM
is there any possibilities to mix water+oil+air?Or air will be soluble in water?
what i try to do is to emulates the fluid flowing from oil reservoir for study purpose.
Re: mixing air with water/oil
10/05/2009 12:45 PM
Put some vegetable oil in a blender, and mix on high speed for "x" seconds (or minutes, if you feel so inclined)...
The foam indicates a pretty good mixture. But, that's all it is, is a mixture ~ which will naturally separate-out into the oil on bottom, air (a gas) on top.
Granted, some gas can be dissolved-into an oil (just as some is dissolved into water, including seawater). But this is not in large quantities.
Same is true for water. Mixture can easily be accomplished. But it will also undo itself in short order.
Why would such a 3some-mixture exist in an oil reservoir I am wondering?
Good Answers: 58
10/06/2009 8:59 PM
They certainly do mix in my car when I have a water leak into the oil. I get a brown mix. If you are emulating the flow from a reservoir at rest, the water will sink to the bottom, the oil will float on the top. If the reservoir is agitated you will get a mix. Add a little soap, and they will mix into an emulsion.
mike k
