Previous in Forum: MCB tYPES   Next in Forum: What is the meaning of letter L,M,S in motor frame size? e.g.180L =what is L
Turkey - Member - New Member
eddy current drive
10/07/2009 9:58 AM
can you pls give me an explanation of this concept "eddy current drive"
jinxnao
Hobbies - Hunting - Deer and Birds Hobbies - HAM Radio - Achieved Ham Radio license in 2008 Hobbies - Fishing - Fisherman United States - US - Statue of Liberty - Know freedom, no tyranny.  Know tyranny, no freedom. Hobbies - DIY Welding - Beginner
Good Answers: 19
Re: eddy current drive
10/07/2009 10:41 AM
An eddy current drive consists of a fixed speed motor and an eddy current clutch. The clutch contains a fixed speed rotor and an adjustable speed rotor separated by a small air gap. A direct current in a field coil produces a magnetic field that determines the torque transmitted from the input rotor to the output rotor. The controller provides closed loop speed regulation by varying clutch current, only allowing the clutch to transmit enough torque to operate at the desired speed. Speed feedback is typically provided via an integral AC tachometer.
Eddy current drives are a type of slip controlled drive. Slip controlled drives are generally less efficient than other types of drives. The motor develops the torque required by the load and operates at full speed. The output shaft transmits the same torque to the load, but turns at a slower speed. Since power is proportional to torque multiplied by speed, the input power is proportional to motor speed times operating torque while the output power is output speed times operating torque. The difference between the motor speed and the output speed is called the slip speed. Power proportional to the slip speed times operating torque is dissipated as heat in the clutch.
Source Wiki
Go green, use a solar powered light saber...
