Previous in Forum: info on coke   Next in Forum: vacuume pump + vacuum box supplier
United States - Member - Member Engineering Fields - Manufacturing Engineering - Member Hobbies - Fishing - Member
Measuring Roll-Formed panels or Panel Checking Blues
10/07/2009 3:55 PM
What is the best way to verify profiles and specific plane dimensions on roll formed panels? We currently employ profile "Go/No-Go" gages, calipers, protractors, tape measures, radius gages, etc. I would like to discover a method to verify dimensions and profiles less subjective to the user. Something more consistant. A CMM is out of the question.
Any ideas??
"Stepping up to the plate" is not enough, you have to swing to get a hit!
Re: Measuring Roll-Formed panels or Panel Checking Blues
10/08/2009 8:34 AM
Look into an on line inspection system that uses line scan cameras.
Good luck, mkh
