Previous in Forum: Floating Neutral   Next in Forum: Type of Switch
termination of cable
10/11/2009 9:35 PM
Dear, All
is possible to use bolt & nut stainless steel 316, to terminate the power cable on the buss bar. any problem will arise.
Please advise.
Re: termination of cable
10/11/2009 10:46 PM
10/12/2009 7:02 AM
Yes, you can do this but why use such a soft bolt.. you should use a grade 8 bolt with lock washers. 316 stainless bolts are very soft. I use grade 8 yellow anodised bolts. these are the same bolts the panel manufactures use. good luck
You might be interested in: Bolt Tensioners, Cable Laying Services, Nut Runners
