Previous in Forum: Battery Charger   Next in Forum: Wrist-Mounted Body Temperature Sensor
India - Member - New Member
Motor Torque, Voltage, Current and Frequency
10/12/2009 10:41 PM
I need a formula for VFD Motor Torque, Voltage, Cueernt and Frequency. If any xls sheets for VFD motors Torque vs Speed, Currnt, Fequency.
Arun Babu
Good Answers: 804
Re: Motor Torque, Voltage, Cueernt and Frequency
10/12/2009 10:47 PM
You need to contact motor manufacturers, every motor is different. But most manufacturers will supply a torque-speed curve. You would likely need to extrapolate it into a spreadsheet yourself.
But that would be for the motor as a fixed-speed device. With a VFD, the torque remains constant throughout the speed range, that's the primary job of a VFD. Accuracy may suffer at lower speeds based upon what kind of VFD you are using, so that must be determined in advance.
Good Answers: 244
10/13/2009 11:11 PM
10/14/2009 8:47 AM
Thank U...I got the bacis details
Arun Babu
Register to Reply 3 comments
arunbabu (1); JRaef (1); msamad (1)
