Previous in Forum: Type 2 Coordination for 3.3 kV Motors   Next in Forum: Squirrel Cage Electric Motor
Formula for Cable Sizing
10/13/2009 5:50 AM
Dear Sir,
still i have confuse in cable size choossing for diffrent kw, can you help to give the formulae for cable choosing
Re: cable size
10/13/2009 6:15 AM
Re: cable size
10/13/2009 7:06 AM
fast way is :
1. convert kw to ampere
2. then see in catalog, for that ampere (already times by 1.1 for safety factor) which size cable will be used.
ex : cable 600V,
untill 25 A can be used 12 AWG
untill 35 A can be used 10 AWG
for detail way you must consider :
1. cable purpose : is it for power, control, VSD, so you can decide how many core used for 1 cable.
2. short circuit capacity your system, so your cable will not burn when short circuit occur.
3. Voltage drop. if you have distance from panel to your equiment (for example pump) is far enough. may be your cable able to be flown by current as big as that ampere but if voltage drop is too big, you must enlarge your cable size..
remember : VD = I.(Rcable.cos phi + XLcable.cos phi)
regards
Re: cable size
10/21/2009 4:11 AM
I think VD = I (Rcable Cos phi + XL Cable Sin Phi)
Your answer mentions XL Cable Cos Phi again.
Am I right, Sir?
Re: cable size
10/13/2009 2:47 PM
Also see the numerous previously answered threads on CR4 on this commonly asked question.
Re: Formula for Cable Sizing
10/21/2009 5:52 AM
please refer IEC 287 all parts .
ALso u can refer BS 7671 it is very well documented
Correct me if i am wrong i am learner
Anonymous Poster (1); elect-ok (1); ikhanuk (1); jack of all trades (1); lyn (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
