Previous in Forum: KNAN, KNAF,ONAN, ONAF   Next in Forum: How to Calculate CT Ratio and PT Ratio
Signal Cables
10/16/2009 12:23 AM
Dear Sir / Madam,
Good day!
1. Is there will be a problem if i use 1.5mm2 0.6/1 kV CVV cables as a signal cable rather than using a 24V DC signal cable? The cable will go to instruments (Flowmeter, level indicators, etc.) and it will use as a pulse and analog signal (4-20mA).
2. What would be the dilemna if i will use power cable or control cable instead a right signal cable for the equipment?
3. What normally brand was use in oil and Gas industry or in waste water treatment plant?
Thanks,
Philip
Re: 0.6/1 kV CVV cables use as a Signal cable?
10/16/2009 2:24 PM
Most possibly you will burn your cirquits. No level indicator can handle 1KV (that 1KV cable always carrys as you know)
Re: Signal Cables
10/18/2009 3:06 PM
Short answer, possibly due to the fact the CVV cable has no screen.
http://en.wikipedia.org/wiki/Electromagnetic_interference
Depends on site standards. Consult the site standards, tender information, etc.
Register to Reply 2 comments
