Previous in Forum: PROVIDING INSULATED BEARING FOR VFD APPLICATION for NON-DRIVE END OF THE MOTOR.   Next in Forum: hydrometer for lead acid battery
capacitor
10/17/2009 9:09 AM
how does the capacitor works on a motor
Re: capacitor
10/17/2009 9:23 AM
Re: capacitor
10/17/2009 10:12 AM
The first post gives you a very good explanation of how capacitor works. Typically a single phrase motor will have two sets of windings, a run winding and a start winding. Some means of throwing the windings out of phase is a necessary or the motor will not self start (a simplified explanation there are repulsed start motors as well as different resistant winding) current lags by 90° in a pure inductor, and leads by 90° in pure capacitance.
In this very simplified explanation a circuit containing induction and capacitance will be out of phase a regular motor winding (virtually purer inductance) so basically you're telling the motor which way to TURN. Capacitors can also be used increase the starting torque and then drop out of the circuit once the motor is rotating.
The subject is far too complex to discuss in a post. There are many good books available on basic motor operation. If you are trying to figure out why your garage door opener doesn't work and the oval capacitor is almost round it's worth going down in buying one to replace it. A lot of good motors get thrown away because of bad capacitors.
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
Re: capacitor
10/17/2009 3:16 PM
on the way with Mr. Guru's answer:
basically capacitor is used in a motor for make the motor self starting.
Capacitor generates a split phase i.e. phase shift in the currents of two winding Run winding & start winding .
In other word, capacitor generate a artificial phase voltage.
Thanks
Hobbies - Musician - Tube Amps Only Please!
Re: capacitor
10/17/2009 10:22 PM
This will tell you everything you want to know: http://en.wikipedia.org/wiki/Motor_capacitor
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
dhanesh.koshti (1); lyn (1); maveric_manic (1); YWROADRUNNER (1)
