Previous in Forum: Generator Capacity and Transformer Load   Next in Forum: Transformer Copper Losses
Flat Belts vs. Poly V Belts (Cogged Belts)
10/23/2009 1:43 AM
Dear Sirs,
Greetings!
Can you please tell me that out of Flat Belts and Poly V Belts (Cogged Belts) which is more energy saving? And what would be that % range?
Has anybody tried it or if any case studies or technical catalogue/material could be shared, i request you to kindly bring forth.
The proposed application lies for the motors in Winder & Unwinder machines for the cable industry.
Request for your inputs at the earliest.
Regards
Good Answers: 183
Re: Flat Belts vs Poly V Belts(Cogged Belts)
10/23/2009 10:11 AM
www.shristiengineers.com
Advantages of flat belts are listed but since its is manufacturer or supplyer of this kind of belts the comment is "coloured".
Hobbies - CNC - New Member Canada - Member - Finaly got around to it.
Good Answers: 12
Re: Flat Belts vs. Poly V Belts (Cogged Belts)
10/25/2009 7:49 PM
I always use cogged belts. They run cooler and transmit more horse power. The most important feature is that based upon the manufacturer, a standard V belt will snap as a cogged belt will hold on and run on threads to the bitter end.
Register to Reply 2 comments
