Hello All,
I tried Mechanical sizing of a Centrifugal Compressor with following conditions
Flow rate 31.81 Kg/s
Inlet Capacity 3252 dm2/s
Inlet Pressure 10.4 bara
Discharge Pressure 62 bara
Inlet temperature 43.55 oC
Mol. weight 23.77 KJ/kmol
Cp/Cv 0.925
However on calculating at ploytropic conditions, the Estimated Power is about 10500 KW while the discharge temperature is about 250 oC which is way above the maximum allowed per stage. In my own opinion this should call for a second stage with interstage cooling.
I would like to have a second opinion and maybe alternative calculations step if different significantly from my results.
Regards
