Previous in Forum: general   Next in Forum: Switch gear development
VFD transformer oil filtering (regeneration,purifier, purification)
01/08/2007 3:34 AM
Application(oil filtration, oil purification, oil recycling, oil treatment, oil regeneration, oil restoration, oil filtering, oil filter, oil purifier, waste oil disposal, oil reclaiming, waste oil management, energy saving, oil reconditioned, oil reconstituted, oil restituting, oil recovering, oil recuperation, oil filtrating, used oil, industrial oil, oil remediation, oil processing)
VFD insulating oil purifying series is mainly used to improve the properties of insulation oil. It can remove trace water, gas, particulate matters etc. from the insulating oil effectively and rapidly so as to boost performance of transformers, circuit breakers, mutual inductors, cable and capacitors which has insulation system. VFD oil purifying series specialize in purifying branded oil, insulating oil of high voltage and super high voltage transformer. Additionally, it is suitable for treating low viscosity lubrication oil.
Insulation oil regeneration system is a de-acid device which is designed to treat the old transformer oil, the used transformer oil and fullers earth will be fully reacted in this system and the property of transformer oil will be perfectly recovered.
wooden case
Product Catalogue
Insulation Oil Series
VFD Double-Stage High-Efficiency Vacuum Insulation Oil Purifier
VFD-A Double-Stage Vacuum Insulation Oil Automation Purifier
VFD-R Double-Stage Vacuum Insulation Oil Regeneration Purifier
VFD-T Double-Stage Vacuum Insulation Oil Purifier with Tester
Turbine Oil series
TF Turbine Oil Purifier
TF-A Turbine Oil Automation Purifier
TF-R Turbine Oil Regeneration Purifier
Lubrication Oil series
LV Lubrication Oil Purifier
LV-A Lubrication Oil Automation Purifier
LV-R Lubrication Oil Regeneration Purifier
Gas Engine Oil Regeneration System
GER Series
Should any of these items be of interest to you ,please search for "sinonsh99" at google for more details about oil purifier machine
