Previous in Forum: Transformers: Restricted Earth Fault vs. Differential Protection   Next in Forum: Control and Protection Circuit for Palleling Transformers
Earthing Armored Cable
11/10/2009 12:31 PM
Is there any problem if we earth the armour of the cable at both ends?Should we take precaution in that case as not to earth the both armour of the cable ends.
"Know something about everything and everything about something"
Re: Earthing Armored Cable
11/10/2009 4:02 PM
Do a google search for the term "Ground Loop".
I am not an electrical engineer but,
I think you will find having more than one ground is usually a bad idea.
Good Answers: 42
11/10/2009 7:34 PM
This subject was discussed earlier also in this forum( thread on on 07/24/2009)
http://cr4.globalspec.com/thread/40950/Armored-Cable-and-Earthing
Good Answers: 170
11/12/2009 9:14 AM
If it is a multi-core cable, then there is no issue in earthing the cable armour at both ends. But, if it is a single core cable, then earthing at only one end is mandated, as earthing at both ends, in such a case, would circulate eddy currents in the armour and heat it up.
Register to Reply 3 comments
Calnet42 (1); electricalexpert65 (1); V.I.Abraham (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
