Previous in Forum: L/G ratio in Cooling Tower   Next in Forum: owner
Lateral Vibration vs. Torsional Vibration
11/11/2009 4:25 AM
Dear Members,
I need to expalin the differences between lateral vibration analysis and torsional vibration analysis.
It is so expertise for me to understand all.
Can anybody explain for me?
1. what is the major differences between lateral and torsional
2. what are their purpose and/or intention?
Pathfinder Tags: vibration
Re: Lateral Vibration vs. Torsional Vibration
11/11/2009 10:20 PM
Tortional vibration is "twisting".
Lateral vibration is "shaking".
11/11/2009 10:39 PM
Lateral Vibrations is something like your hand movement while walking.
And
Torsional Vibrations is something like, somebody twisting your hand again and again.
11/11/2009 10:44 PM
those two answers should get you a 'pass' in your assignment. Quick, brief and concise.
11/12/2009 2:59 AM
As said above lateral is shaking or side to side or up and down, the trace is like the audio one many players show - a left to right flow of peaks and troughs.
Torsional vibration is twisting or springiness in a shaft or drive train or crankshaft main bearing in a IC engine. The trace is usually a polar diagram, or a circular ring of peaks and troughs.
Both are used to identify problems, and/or to determine the fatigue life of a part or assembly. They can be analysed separately or together, as frequently one can cause the other. For instance lateral vibration in the tail of an aircraft produces torsional vibration in the fuselage. The firing of pistons in an engine twists the drive shaft
“Don’t worry, they usually don’t swim backwards.” Steve Irwin
11/12/2009 9:50 PM
Nor really. Springiness is there in lateral vibrations also. The movement of shaft around its own axis and repeatations there of is the torsional vibration.
No, I disagree. Both are not used to identify the problem. These vibrations are themselves a problem. Analysing those can give a solution to a problem.
11/13/2009 12:26 AM
So you disagree that the sequential stress of pistons firing causes torsional vibrations in a crankshaft main bearing? - interesting. Then I wonder why people put vibration isolating couplings between IC engines and loads? I wonder how you would optimise a flywheel on a direct drive gen-set?
And you disagree that analysis can identify vibration sources? equally interesting.
Perhaps you are under utilising your equipment?
But just out of interest- how would you like me to explain something to a person of unknown experience?
And - who before me attempted both parts of his question?
And what is this? "These vibrations are themselves a problem". Can you name one thing that rotates; from a clock escapement to a megawatt turbine that has zero torsional vibration?
11/12/2009 9:37 AM
I would like to add a couple of different words that might help the understanding of those you have to explain to.
Torsional vibration would be rotational, about the Z axis if you want to think that way.
Lateral vibration could also be called transverse vibration, along the X or Y axes (or a combination.)
There is also axial vibration, along (instead of about) the Z axis.
Lehman57
Register to Reply 7 comments
Anonymous Poster (2); gsuhas (2); Kyzine (2); Lehman57 (1)
You might be interested in: Vibration Instruments, Vibration Sensors
