Previous in Forum: Controlling Hydrogen Purity   Next in Forum: Supplier SAPH 440 steel in indonesia?
Location: Wake Forest, NC USA (in Central NC, God's country)
How to Validate an HPLC Method
11/13/2009 4:02 PM
I have a background in synthetic chemistry but am not well-versed in aspects of quality control/assurance. I have now been asked to validate an HPLC method which has proved to be suitable for our needs Specifically, we have developed a method for the quantitative determination of an antimicrobial agent in our formulations. An outside auditor states that the method needs to be validated, and I am not sure what needs to be documented in order to show this. Intuitively I feel that much of the work has already been done, but isn't there a step-by-step format for spelling it out? Thanks for any help.
“Better to remain silent and be thought a fool than to speak out and remove all doubt. - Abraham Lincoln”
Re: How to Validate an HPLC Method
11/14/2009 4:10 AM
Ask the outside auditor what is required.
Good Answers: 19
11/14/2009 9:16 AM
I would imagine a proper job of it would involve a calibration curve done in triplicate , and determining the detection limit. The calibration curve should cover well above and below the expected concentrations. Then test any samples of known concentration to see how you compare. The detection limit is important so that it you report "Not Detected", it is known to less than that value. Also, if you have a auto sampler and programmed analysis capabilities, make sure they are properly set up and documented so if you get hit by a cement truck, your replacement can come in and pick right up on it. Doing in triplicate allows you to do statistics on repeatability of your technique. But I agree with the other post , and ask specifically what they require to make sure you are both on the same page.
...That's why we call it "Research"!
11/14/2009 10:27 AM
Asking the auditor is a wonderful idea. I know from my own experience with our hplc, that doing a 5 point calibration works wonderfully. Some people might do a 3 point calibration as mentioned earlier, but honestly, the more points the better. 1 point is basically meaning less, 3 is good, 5 is better. The more you have the better you are statistically, and you will have a much better time proving to your auditor the reproducibilty of your method.
Register to Reply 3 comments
Anonymous Poster (1); lyn (1); wcfloyd (1)
You might be interested in: Step Recovery Diodes, Stepper Motors, Chuck Jaws
