Hi just bought a 300 amp tig welder (UCC-305)with ac facility for welding thin aluminum..Ti has three ranges of power,,3 to 55 amp,,7 to 230 amp and high at25 to 300 amp...Problem is in-put power spec is 240 volts at 94 amps ,,this is heavy duty inputs,,,when I only want to use low power 3 to 55 amp...normal mains at home is 240 volts at 45 amps max,,,to get full power installed for the welder will cost £££..
would it be possible to couple up to what power I have and just use it on the lower
current settings..with a good 40 amp fuse protection or will I have to spend to get full power installed.......thanks bobin
