Previous in Forum: Cam Overlap   Next in Forum: 1998 Chrysler Town and Country - Lxi Transmission Stumbles
Frit on Windshields
11/17/2009 5:24 AM
Now a days almost all vehicles have a black coloured patch called FRIT along the periphery of windshield.It serves two purpose..1) to protect the urethane based adhesive from UV radiations and 2) to add aesthetic value to the car and also act as extended sunvisor in some cases. Here I have a basic doubt of How is frit made. Is it attached to the glass.How???? I tried a lot but was not able to get sufficient and satisfactory information. Please provide what all info you have..
Thanks in advance
Heman2727
Re: Frit on Windshields
11/17/2009 6:05 PM
Well, I found a little bit, all from internet sources:
http://www.carwindshields.info/glossary.htm At this website, the definition of 'Frit': This is the painted black band around the perimeter of the windshield. The adhesive is underneath this band, so the band is able to help protect the adhesive from damage from the sun.
If I wiki 'frit' I get a lot of information I never knew (if I did, long forgotten) about glass. I do not get any application to the auto industry at all. It looks like a circumstance of a word having two distinct meanings.
Hope this is of some use to you.
Good Answers: 11
11/18/2009 8:17 AM
In the hot glass business "frit" is a low melting point glass that is used to solder two higher melting point glasses together. This is how the funnel glass and panel glass on a CRT tube are mated. I don't know why the word is used for a windshield. Maybe the layers of glass used to be soldered together with frit at the edges back in the day?
Eric
Good Answers: 68
11/18/2009 7:26 PM
Hi heman,
This area of enamel is called a "frit" and is a black enamel which is baked into the edges of a windscreen. It served several purposes.
It strengthens the edge.
It has a Matt finish to allow better adhesion of the glue to the glass.
It also helps to prevent solar (Ultra-Violet) damage to the adhesive area, where the glue adheres to the car body on the inside.
In older cars there was no need for this as the windscreen was held in place by a rubber molding. Grooved on the outside, which fitted the car body, and the inside edge which the glass slid into, and so was held in place.
Check out these few sites which will explain how it is done.
  1. MAKING YOUR OWN Jump to Frit‎: It is possible to buy frit-making machines, called "glass crushers." Alternatively, you can rig up your own machine using a garbage ...
    www.warmglass.com/making_your_own.htm
  2. Tag: Frit - Explore content tagged Frit on eHow.com Frit is a versatile design medium and is perfect for making shapes that are ... The windshield on your Chevy Silverado 1500 should be trouble-free for the ...
    www.ehow.com/tag/frit/
  3. Seeing dots on windshields 26 Jul 2002 ... A: Windshield glass contains a black enamel band (called the frit) around the periphery that is baked into the glass.
    www.wonderquest.com/windshield-dots.htm -
I hope you find this helpful.
11/19/2009 8:47 AM
I have seen this put on. It is screen printed on then run through a dryer to dry/ cure the paint
01/24/2010 11:09 PM
thanks senator.
I have noticed one more thing.There are dots on periphery of frit in some cases and in some those dots are not present. What is the reason behind providing dots?
thanks in advance,
Heman2727
babybear (1); ca1ic0cat (1); Doorman (1); heman2727 (1); senator46 (1)
You might be interested in: UV Filters, UV Sensors, UV Light Systems
