I have been looking for a test panel that has the ability to test single and poly phase motors ranging from 1 to 4kw 120 to 230v single phase and 1.5 to 120kw 230 to 575v three phase. All in 60Hz.
This panel must be able to provide the proper short-circuit and overload protection.
Only one motor will be tested at any given time.
A MCC is not an option due to space limitations
I have looked at panels with the output connected to a common buss which is fed from different power sources through interlock systems, with a master contactor on the output for safety interlock disconnect. The drawback with the master contactor, is that it must be sized to the maximum load and disconnecting loads less than what it was designed for could cause problems.
Company policy does not allow mercury contactors.
Any suggestions?
