Previous in Forum: Sheilded Control Wiring - Tied to Ground or Tied to Common?   Next in Forum: First Pole to Clear Factor
LL & LG Fault Causes Negative Sequence Current?
11/18/2009 9:16 AM
line to ground and line to line fault cause negative sequence current in system?
Re: LL & LG Fault caues negative sequence current ?
11/18/2009 3:53 PM
Are you asking why this happens or whether this happens?
11/18/2009 8:34 PM
Good Answers: 170
11/22/2009 4:50 AM
Any Assymetrical Fault (a fault that does not involve all the three phases) will produce Negative Sequence Currents. So also in your case.
Re: LL & LG Fault Causes Negative Sequence Current?
11/18/2009 9:01 PM
One of the main contributors to the negative sequence is the system unbalance.
(Your question is answered).
Register to Reply 4 comments
Anonymous Poster (2); electricalexpert65 (1); JOSHIKD (1)
You might be interested in: Line-shaft Spools, Power Line Network Components
