Previous in Forum: Visual Examination of Longitudinal welds in pipelines.   Next in Forum: VS4 Pumps - Shaft Length Limitation
Question on studs and their thread.
11/22/2009 6:01 AM
Hello!!!
There is flange NPS 24.
According to UG-12, studs shall be threaded full length
According to the table 1C (page 12, ASME B16.5-2003):
Studs shall be threaded to Class 2A according to ASME B1.1. For use with flanges conforming to standard ASME B16.5-2003, the stud nominal diameter should conform to a size specified in the conforming table of standard ASME B16.5-2003, depending on the Class and a nominal size of a flange. In our case as the flange Class – 300, the stud nominal diameter should be 1 ½ in, and length of a stud 230 mm (tables 10, page, 78, ASME B16.5-2003).
Tell what should be thread form and series (UN, UNF, UNC etc.), and number of threads per in?
Depending on what these parameters are defined?
Good Answers: 61
Re: Question on studs and their thread.
11/22/2009 8:08 AM
Are you trying to make your own Studs?
If so....
Why don't buy them?
Do it once and do it right
11/22/2009 10:07 AM
No, I on the contrary do not wish to make. I am going to buy. But to the supplier of studs, except a nominal size of the stud, asks to specify - number of threads and thread form (series).
I know, there are alternatives of studs which are marked out as follows:
1 ½ - 6 UNC – 2A
1 ½ - 8 UN – 2A
1 ½ - 12 UNF – 2A
1 ½ - 16 UN – 2A
1 ½ - 18 UNEF – 2A
1 ½ - 20 UN – 2A
1 ½ - 28 UN – 2A
Where:
1 ½ - Nominal size
Numbers (6, 8, 12, 16, 18, 20, 28) – number of threads per in
UN, UNF, UNC, UNEF, - thread form and series
2A – Thread class
With the nominal size and a class to me all is clear. (According to the table 1C (page 12, ASME B16.5-2003)).
But here with parametres, number of threads and thread form, it is not clear. How to prove their choice.
In what paragraph ASME or the standard it is told about it?
Which alternative, according to ASME, is correct.
I am afraid it will turn out so.
I will order 1 ½ - 8 UN – 2A. And it agree ASME it incorrectly. It was necessary to order, for example 1 ½ - 6 UNC – 2A
I ask your help. What variant to choose?
Good Answers: 61
11/22/2009 12:20 PM
For piping applications you should standardize and use common sizes and threads throughout your plant when ever possible.
Stud Bolt & Nut threads:
1" diameter and smaller = National Course (NC)
1-1/8" diameter and larger = 8 thread/inch
11/22/2009 9:03 PM
mageslay
Go with PennPiper (as usual). This is the norm for most Petrochemcial sites.
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
11/24/2009 1:18 AM
Try this. SA193 & ASTM 193 B7 Stud c/w A194 2H Heavy Hex Nuts
1-1/2-8 gives you a clamping Load P lbs 110,325 @ 3,076 FT. Lbs. (dry) or 2,303 FT. Lbs (lube)
This is a common stud and used in the Petro Industry.
Note: Don't ask me to tighten all those damn studs.
Could be worse, it could be me. :)
12/02/2009 1:43 AM
PennPiper
Thanks!
And where in ASME it is written?
Register to Reply 6 comments
Anonymous Poster (1); mageslay (2); mayt2u (1); PennPiper (2)
You might be interested in: Studs, Leveling Feet, Pads and Glides, Cam Followers
